Originally Posted by yngndrw Thank you for your help. It seems the only issue with this setup would be calculating the power output of the spindle and the required power of the endmill.
I contacted the company who seem to make them and they seemed to suggest that "Air tools cannot be measured in Watts.", I think there were quite a few translation errors mind.
I will use all of this information for a home-made high speed spindle however, so thanks again to everyone.  |
Strange... Personnaly, I've a 25Watt air spindle. If the cutting power is lower than 25Watts, it works, else the spindle stops
