  #12   Ban this user!
Old 06-26-2008, 11:14 AM
msomerville msomerville is offline
msomerville is on a distinguished road
If you are doing low volume parts I would stay away from PCD. There is no reason that you can't achieve the finish you need with the right insert and boring bar. There is an insert I use from www.toolmex.com it is a ccgt-ak high polish insert that might do the trick with a slightly bigger boring bar. Really you should be able to get it with the size you have.
