I am using A 2008 haas vf3 with a 2 axis trunion table. We probe ports, chambers ect in 5 axis mode, using master cam to drive the probe . I had a custom post that was writting for my application by my mastercam dealer.
We can probe a port in 20 minutes, pull the data into mastercam, tweak the data, and lay down a tool path pretty easy, and cut away. The finish on my ports are perfect, and I can push the machine as fast as the cutter can handle it.
I will say this, get a 5 axis trunion table on your machine, haas makes them. I have some friends, with rotarys stacked on a rotary and so on, and they don't work correctly.
The only way to CNC port heads the right way, is on a 5 axis machine, and to probing on the machine is a big plus also. You probe on the machine you cut on. There are a few companies doing this now.
Talk to your mastercam dealer about them getting you a post that drives 5 axis, and will drive a probe, G31 protected moves.. The post will not be free, they will charge you for it.
They have post that will drive a probe.
Good luck.
__________________ HAAS VF3-5 axis trunion
Mastercam X3 |
