Old 09-08-2004, 12:19 AM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Todd,
A 134 alarm shows as a tool clamp fault..so check that number again.
Next have a look at the counter balance cylinder pressure..should be 600 psi. I think that may be what your alarm is all about.
If it goes below a set pressure then it will not let you start the machine until you get the pressure back up to what is required. It is a small tank of nitrogen that is hooked to the hydraulic counter balance. The will be a gage and a pressure sensor along with the hose to the counter balance.
This takes a special "Scrader" fill chuck to fill the tank..as it is very high presure..don't try a regular tire chuck or air ..only nitrogen..bad things happen if you don't..be safe.
If it turns out to be this, it is best to call the dealer and let him do it. He has all the right stuff.
This may not be it, but is a place to start.
