Thread: Newbie Limit switch Error
Old 06-24-2008, 05:14 PM
Gir Gir is offline
Gir is on a distinguished road
Are you cutting wood or metal? I have some good cable but it's bunched together, but it's shielded. When I cut wood no problem, when I cut aluminum I have to turn the limits off because, I suspect, of noise.
Sounds more like a vibration issue. Wiring your switches normally open will fix chatter issues (unless you're getting some really bad vibes), and wiring your switches normally closed will help with noise issues (but might not completely fix them).
