Thread: Dremel Runout
Old 06-23-2008, 03:35 AM
Larry83301 Larry83301 is offline
Larry83301 is on a distinguished road
Try rotating the end mill up to 90deg in the collet and see if this helps. If the collet is off center this should cause the end mill to cut a larger or smaller hole depending on where the cutting edge is in relation to the offset in the collet.
