This is a vac jig I just completed for engraving some parts
that I make. As you can see it is a basic vac pump that has a filter,
vac gage and connects via the coil hose to a ball valve which is
connected to the jig I've made. The jig consists of a hollowed out
base with an o-ring groove and o-ring to seal to the top plate when
installed.
The top plate has a nesting cavity with it's own o-ring to hold the
parts I make (triangle with holes) for engraving. This allows a nice
quick change from one part to the next. What's nice about this setup
is the fact that I can make more top plates and interchange them from
one style of part to the next via dowel pins for location each top
plate.
I'm so please with the way this works and thanks to those who helped out with this!
__________________ Dave->.. |
