Old 09-06-2004, 07:59 PM
ger21's Avatar
ger21 ger21 is offline
First, do your motors lock up when you turn on the power supply? If not, you have a problem. If they do lock up, it's probably a TurboCNC configuration problem.
Can you hook it up with just the cable that comes with the Xylotex? This will tell you if your parallel cable is good or not.
Pulse width should work fine from 2-5uS.
Make sure you set the right parallel port in TurboCNC.
