Originally Posted by tauntdesigns I've had good luck with mine.
As far as the multi-functions go, as of right now, I'm only using the charge pump, EN & pin 10 as e-stop, and jumper set for com pins to be ground. I'm planning to hook up the limits, coolant relay, and spindle control in the near future.
Jack |
Sounds good then. I noticed that you did a X3 conversion. I think you said you used 600oz steppers.
Are the motor's up to the task or would you recommend bigger size motor's?
I am thinking of using at least 400oz+ steppers on my conversion...
(What did you think about your CNC Fusion kit?)
Sorry for all the questions,thanks for the replies.
