Old 09-05-2004, 11:32 PM
chuckknigh's Avatar
chuckknigh chuckknigh is offline
Gold Member
chuckknigh is on a distinguished road
If it was me, I'd go for direct drive coupling to the lead screw...forget about gearing unless the motors are just way undersized.
As for the arrangement, I'd keep the X and Y motors the same, and put the oddball on the Z axis, perhaps with a finer pitch screw, to compensate for the lack of resolution you'll be getting with the 7.5 deg stepper.
As for the relationship is gearing, 2:1 means that for every 2 revolutions of 1 shaft, 1 revolution happens on the other one. Depending on which way you're going, it means your assembly would deliver double the torque at half the speed, or vice versa.
-- Chuck Knight
