Old 06-18-2008, 05:59 PM
CarveOne CarveOne is online now
CarveOne is on a distinguished road
They will feel rather tight on an uncoated or anodized single start acme rod. That is the spring tension forcing the white delrin part against the face of one side of the two screw threads and the black delrin body against the other side of the two threads. The delrin parts are in effect pinching the threads. My 1/2-10 single start rods and DumpsterCNC ABNs worried me at first also. I have new 1/2-10 5 start rods in hand and the ABNs will arrive by Friday. I expect the tightness to be almost 5 times greater.
The spring that DumpsterCNC uses seems kinda tight to me, but once the delrin wears in a little it should ride on the rod a little easier during operation. You can help it by spraying or brushing a light oil on the rod, letting the excess run off, and let the remainder dry a few minutes to evaporate any solvents that allow it to spray. Then try screwing the ABN onto the rod again. Delrin is not harmed by most light general purpose oils.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
