Old 06-17-2008, 09:35 PM
Crevice Reamer's Avatar
Crevice Reamer Crevice Reamer is offline
Crevice Reamer is on a distinguished road
If you measure the force at the crank handle, and the diameter of the crank, there is a formula for calculating the motor size needed.
You have that 2/3 idea wrong. If you have say, 3 motors and each one draws 4 amps (for a total of 12 amps)--then the smallest power supply you can use has to be capable of supplying 8 amps
CR.
