I just got a reply from the builder:
Go to Home Depot and buy two steel angles and screw them on the sides of the table top, that will prevent it to sag. When you remove the table top also remove the motor/lead screw and replace the nut(the part that I sent you) on the base of the gantry. |
So that seems pretty reasonable. That will help to normalize the bed...
