what about the 5th & 6th faces? | | It's strange that nobody mentioned the old trick that allows one
to face the last 2 faces without using a square or an indicator on
the part and also not cutting with the side of the tool...
It is possible and is usually the first exercise in a milling course...
Hint: You must perform 3 cuts instead of only two for the last
2 faces.
If interested, I will post a link
Nelson |
