Hey all,can,t seem to figure out which pin on my bob is for which axes. First off my home switches are the magnetic type and all three have three wires red,green and black. I use CNCPRO and in the software X is pin13, Y is pin 12 and Z is pin 11.On the bob I have a 10 pin connector 1 through ten starting at the top, you will see in the picture. My red wire is on-5 and my black is on-6. I assume red is power and black is ground. Pin 1 has a white wire ,pin 4 has a green wire and pin 7 has a blue wire. Comeing out of the bob the red wire is joined to all the red wires from the switches and the black wire comeing out of the bob is joined to all the black wires from the switches. This leaves me with three green wires from the switches . I,ve ried a process of elimination by putting a washer in one switch and joging any axes to see whitch one would trip and then reversing those wires but still messed up. I don,t know if this makes any sence but just cant seem to figure it out, Iv,e tried switching pairs back and forth to no avial. |
