What type of volume/year is the production requirements?
Sound pretty "unmakable" on a swiss to me...at least economically.
The problem with the swiss will be the distance between the Collet and Guidebushing. You are "pushing" the material through the guidebushing and at .003 wire, this will be a tremendous up hill fight.
Sounds like you need a rotary transfer or trunnion machine. Maybe even some type of wire or spring forming machine could do this.
That being said, if your volume is low and you made it out of larger material, the above link to MCC's "R" would be a good bet.
Good luck with your quote. |
