Old 09-01-2004, 08:31 AM
jderou jderou is offline
jderou is on a distinguished road
Thanks for the info, I am planning on running a flood coolant when I try it (no air compressor yet). I think the machine should be rigid enough, I just don't know if the router will have enough torque for a decent feed rate.
Does anyone have advice on fixturing? When cutting something out of a sheet, how do you keep the piece you are cutting out from moving on the final cut?
I'm pretty much new to machining metal, I've been working with wood for a while but that's easy.
