Old 09-01-2004, 03:18 AM
ESjaavik ESjaavik is offline
*Registered*
ESjaavik is on a distinguished road
It is just a bushing, but with the benefits of very low friction. You can make a slit in the bearing block and thus adjust the preload. You can also get them with a segment missing (open on one side) so it can be used on a fully supported rail.
The simplest for of bearing block is just a block with a hole. Or the hole can be part of the component it will carry.
