I got it to do what I wanted!!!!!
I just had to edit the G01 to the Z that I wanted.
Apparently the wizard doesn't work properly.
No matter what I did with the depth of cut it would add it to the G00 code.
I tried a + and a - cutter depth and it made no difference.
Now back to the converter.
I have voltage at the plug but when I put a load on the plug the voltage drops to zero.
It is probably some setting I have wrong.
Thanks for the help.
As soon as I get my converter working I will attempt to cut something.
The fun is about to start. |
