Old 08-31-2004, 02:42 PM
ViperTX ViperTX is offline
ViperTX is on a distinguished road
Most drivers are just like a switch you put 12 volts on one side of the winding and you close the switch and the switch only sees the voltage between it's ground and its collector (if a transistor switch). Look at the specs on an inexpensive driver board and how they wire the stepper to it.
