What diameter bit are you using?
One or two flute?
Have you tried spiral up cut or down cut bits?
Do you have a vacuum system on your machine?
It has been advised to me to also turn the router speed down, but I have found the opposite also works for me. I think it must get rid of the junk a lot better and make smaller particals that dont clog up. That last advice is unconventional, but at least give it a try and see if it helps. |
