Old 08-30-2004, 12:30 PM
andyew's Avatar
andyew andyew is offline
andyew is on a distinguished road
As for dimensions, it has working area of (X)770mm (Y)670mm (Z)70mm. The Z is not deep as it will probably cut stuff about that thick (70mm is around 2-3"). It'll be a waste if Z is designed to have "extra" travel distance and it'll be less stable, i think.
Delrin blocks used here are all 50x60x50mm so that it's easier to produce using simply boring tools for the 30mm holes.
Let me know if you need more angle or zooms of the design, thanks!
Andy
