Old 08-30-2004, 08:42 AM
ynneb's Avatar
ynneb ynneb is offline
Moderator
ynneb is on a distinguished road
Unless you are prepared to have a very dark room whenever you use it, you would need more than the <5 mW a standard red laser pointer puts out. And this means expensive.
These days you can get very bright and cheap lasers that can be clearly seen in daylight.
2) The scanners are very expensive if you want any accuracy at all.
Accuracy is not that important for just knowing where to put a hold down screw, or where to avoid a bad patch in the material.
