Old 08-30-2004, 01:20 AM
tpworks's Avatar
tpworks tpworks is offline
tpworks is on a distinguished road
Originally Posted by sol
Free advice dept....Do not make the mistake I made of enclosing the base of the router with the vacuum cowl; the router's exhaust overpowers the vac and blows dust everywhere; it was a powerful vac too...
This thread's previous image looks promising with only the bit enclosed.
Also the brush on some vacuum cleaner's sweeper attachment is essentially a flexible metal channel with bristles mounted into it. The channel-bristle assembly is sometimes removable (I've had them fall out while I was vacuuming) and would be great for a custom brush. Probably get the attachment for cheap from a vac repair shop.
Unless you plan ahead and divert the routers air flow, this one works pretty well for me.
Tom
ID:	3299   Click image for larger version
ID:	3300   Click image for larger version
