timan,
It has been a while since I turned everything on. I will take a look tomorrow and let you know what I did. I think??? there was a parameter that actually turned it on. There also was a setting that allowed you to put in the number of coolant positions your particular PCOOL unit has. i.e 20 for the old unit like I have and about 34 or 35 for the new PCOOL units.
This was not a pay code like rigid tapping. Just change the 0 to 1 in the correct parameter and you will activate the coolant position in the tool offset page so that you can edit the PCCOL coolant position for each tool in your tool library. I think I had to turn the parameter lock off then change the parameter push the emergency stop button and reboot the machine and then turn the parameter lock back on. Guess I should have written it down somewhere for reference purposes.
Maybe someone else here can help with the particulars.
John |
