Thread: Need Help! lead in/lead out
Old 06-02-2008, 08:02 PM
jcc3inc jcc3inc is offline
jcc3inc is on a distinguished road
Hello,
Climb milling would be done going CW around a piece. The mill cutter turns CW as viewed from above, so the cutting tool tries to pull itself along the path.
Typically with conventional swirl plasma, you travel CW around the outside, CCW on the inside of a ring, for example. This gives the squarer cut on the workpiece.
Regards,
Jack C.
