Old 06-02-2008, 03:22 PM
timan timan is offline
timan is on a distinguished road
Originally Posted by HelicopterJohn View Post
Hi Mark,
On my TM-1P the biggest issue was taking off the spindle shroud and getting it back on. I had to drill a little hole in the bottom of it and put a grommet in there to prevent chaffing of the cable. Make sure you have the power turned off to the machine when running the cable back to the appropriate pin out on the control board. The Control Cabinet is VERY DANGEROUS place and is filled with some VERY HIGH DC VOLTAGE that can KILL YOU if you get in contact with it. THESE HIGH DC VOLTAGES ARE STILL PRESENT EVEN IF THE POWER HAS BEEN TURNED OFF. If you don't fully understand where these points are and how to avoid them you should get an authorized HAAS Technician to run the wiring and hook it up for you.
John
How did you get around the Haas Code to activate the PCOOL unit?
