What Mastercam do you use? New to this.. | | What's the best basic setup that will do well for your typical 3-axis CNC router?
I see all the options like Design, Solids, Mill, Router, etc. Also, within Mill, it has levels 1-3, and multiaxis.
What should I buy? What is the minimum needed to have "capable" functionality?
Also, does this program run the actual Gcode? Or is it best to use something like Mach2?
Thanks. |
