Old 08-26-2004, 10:12 PM
chozo chozo is offline
chozo is on a distinguished road
Wow, where can I get the hardware to set that type of belt system up?
Also, thanks for the info on the FET board, and reminding me to check back on the HobbyCNC site.
If you do want to use two motors, you will need a 4 axis drive. There are a lot of machines that use 2 motors per axis that work fine, they just have to be well designed and setup. You want to make sure you NEVER miss any steps or you could cause some damage to your machine.
So, the 4-axis controller from HobbyCNC would do well?
