You said in an early post that you tried a newer version of Mach 2. Did you un-install mach 2 and also un-install the driver from the hardware list as well, before you upgraded? Also before you down graded?
I know your problem was before you did the upgrade but maybe the Mach 2 driver went bad.
__________________ Thanks
Jeff Davis (HomeCNC)
http://www.homecnc.info
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
