Start with the blank piece of hardwood. Around this is a square frame, thicker than the thickest blank, with set screws mounted through the sides to lock the blank in place.
This is gripped by a clamping vice mounted on the cnc machine base.
Correctly set up, the frame plus work, can be turned over in the vice, and registration for the second side will line up with the first.
John
__________________ It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse. |
