Originally Posted by Crevice Reamer I agree. except pin 7 of the GECKO is disable. You don't WANT to power that.
CR. |
According to the G201 manual it is disable when grounded. So it should either be pulled up to 5V for enable or hooked to an enable/disable signal from the computer (enable controlled by software).
Actually it may have an internal pullup on it, so you may be correct that it need not be connected to power, I personally use an enable controlled by software, (think charge pump).
Alan
