How to hook up non-standard step signal | | Not sure if this is the right forum as this is not unique to a Gecko drive, however I am using a 203V for this project. Maybe should be in the general electronics section but I bet I get the best responses here.
I have an device that controls a stepper mounted on a water valve, problem is there is a proprietary drive mounted on the stepper that uses 2 inputs, a CW or CCW step signal, and it basically shuts off if not receiving step pulses, this allows the valve to move from pressure & vibration.
I want to use the 203V but need to figure out how to change the 2 existing signals to conventional step & direction.
Thanks!!
__________________ Thanks
Marc
