Yes, you can do chip breaking. What you do is edit your post processor. First the MAC file and there you add a line to drill cycles reading
drill_type = Chipbreak Peck Y
then in the GPP file, to the "@drill" routine, add something some code to format the G code eg (presuming it is FANUC)
if drill_type eq "Chipbreak" then
{nl, "G73 X"xpos" Y"ypos" Q"peck" Z"z_depth}
endif
Have a look in the GPP tool manual, it has it all in there. |
