Old 08-23-2004, 09:22 PM
JWWalthall JWWalthall is offline
JWWalthall is on a distinguished road
Krista,
Do not try to install your own memory as Haas has priority cards and controls. Have you filtered the files in MasterCam? If not that will reduce your file size and also improve your cut. DNC is stable but on a Haas machine be careful how fast you are running your machine,(feedrates). DNC is only as good as the RS232 connection Baud rate so the control will not get file information fast enough ,and the control will then pause until the buffer is full again. My suggestion is to remove all unnessary programs in the control,filter the nci file and you should not have any problems.
