  #11
Old 08-23-2004, 09:07 PM
CNCPlastic CNCPlastic is offline
*Registered*
CNCPlastic is on a distinguished road
Dumb luck really, I turned it around, zero'd X and Y again and it was right on.
What I should have done is clamped the part down, zero'd X and Y, then use the mill to cut two alignment holes equal lengths apart on the part center line. That would have assured that when turned the part around everything would be perfectly positioned.
Originally Posted by IJ.
CNCPlastic: Brilliant!
How did you relocate it when you turned the workpiece for the 2nd pass?
