Can the disable signal be run through a limit switch?
And if so can it be in series with the ground signal from the
controller so that I can still use my e-stop switch to disable
all axis.
I am running a software similar to Camsoft with the Galil card
driving an Ah-ha 3 axis control box.
I am also already using a g210 on my 4th axis, but I never hooked
up the disable because I was unsure if it would cause problems.
I have a full time manufacturing business making my own product and
can not afford down time.
I am so glad I found this wonderful forum, hopefully I can help somebody else
someday the way you are helping me.
Thanks,
Joe |
