Originally Posted by Delw if I understand you correctly you can't get it out of the jog mode once in it? hit the manual button that will take it out of jog |
I`m sorry for my exprimation,if it wasn`t correct but here`s a text from a Fadal manual :
"To enter the Manual Mode of the machine, press the JOG key.Each of the axes position can be zero while in this mode. By pressing the associated letter for the axis, the position display will be zeroed out. For
example, pressing the Y key will result in the Y axis position to be cleared to
zero. This feature can be helpful to set reference points as the machine is
positioned to points on a part print."
thanks again !
