Dan,
Thanks for your post. I assume you were referring to the Plunge Clearance. That seems to add to the Rapid Height for all but the first plunge in the Gcode so I have since set that to 0 and just used the Rapid Height alone.
Still not sure what the "Set Depth" command actually does. It doesn't seem to allow for direct data entry. |
