I just found it, doing what you said. It appears to have a little less than 100 kb. I'm using m'cam9, trying to do some surfacing and it looks like the files will be about 500kb or so.
Is it plain old simm ram, or something more sophisticated?Maybe I could graft in an edge connector for simms? Or am I about to destroy a perfectly good board? I'm a tinkerer.. to a fault, usually.
I'd do DNC maybe. So do the DNC programs out there simply "dole out" the g-code (NC file) at a rate that the haas control can deal with it with its buffer? Or does it require a 2 way communication?
Sorry, but I'm new to this cnc stuff. Lots of autocad experience, can do solids no problem. And i'm getting OK with Mastercam, but ,,,,the buffer is full!
Is DNC pretty stable stuff?
Thanks for the help. |
