Originally Posted by pixburghenat Thanks Jeff,
I'll have to add that to a new PP. The one I'm using didn't come with the source and the var I had wouldn't give it to me.
Over on the CWX forum I posted a message about the same problem with SP2.0 and Glenn replied it was a bug in the roughing pocket, he didn't think it would be fixed in SP2.1
It's not a big problem anyway, I switch to a ramp and it does the same job.
added** That was CWX 08 for SWX 07, I haven't tried it in 08-08 yet.
Scott |
IMO your VAR is a POS for not supplying you with the necessary information you need to get the job done. You purchased the software from them and you probably have yearly maintenance agreements you pay them as well. That really bites.
I will supply you with source code if you need and if I have it.
Jeff Lange
