Old 05-14-2008, 04:19 PM
isubsmith isubsmith is offline
isubsmith is on a distinguished road
Originally Posted by Mike@Torchmate View Post
By aligned I would mean the gear being parallel with the Rail that the gantry rides on, in a vertical alignment. If the rail to gear rack distance vary's over the length of the table, then the gear will ride in and out of the gear depending on location. If you bought your own rails, you might want to check and see if there is any bow to the rails.
Yeah, I've noticed sometimes that the rollers on the gantry don't spin either because they aren't in contact with the ground steel top plate, or they are too tight and get drug along and don't spin.
I've measured the difference between the gear rails at both ends and they differ by maybe 1/16". I suppose we should make another attempt at seeing if we can get it closer to zero difference?
Thanks.
