Old 08-21-2004, 10:08 PM
Al_The_Man's Avatar
Al_The_Man Al_The_Man is offline
Usually the only reason a servo will overheat is because of mechanical overload, most amplifiers have a means, either by potentiometer or parameter to set the current limit. The current can be monitored on some sytems from the operator screen, others you will require to hook up an ampmeter. The correct setting will prevent motor burn out.
Al
