Mach2 & Rutex relay board. | | Up till now I have been turning my spindle on and off manually.
I havent connected the spindle to the Rutex relay board yet.
I have tried to get the relays to respond to Mach2 input but cant hear them click in or out. I have tried to configure the relay board to respond to Mach2's input but have had not luck.
In the Rutex pdf concerning the relay board it says that I need to use pin 14 of the printer cable and use port C./1 . What does C./1 mean.
Has any one else successfully enabled spindle control using the relay board?
