Old 05-13-2008, 06:10 AM
ggamalski's Avatar
ggamalski ggamalski is offline
ggamalski is on a distinguished road
using variables and subprograms to drill in 4th axis
Fadal 40/20 w/mp32 multi control
Tecnara 4th axis
Format 1
Mastercam V9.sp2
I need to write a program that would have operator-defined variables. The parts are cylinders of various diameters and lengths having holes drilled in a grid around then periphery. Rows of holes will be staggered/shifted from each other. Number of holes in each row will vary for 5-20 holes, based on workpiece diameter, as will the depth of the holes, distance between the holes and the numbers of rows. Larger diameter = more holes per row and more rows per part. Some larger parts may have 5000-8000 holes. Y-axis value will always be Y0.00
I.e.;
A pattern like this around the part
_. . . . . . . .
_. . . . . . . .
I'm thinking the operator would have to input the following:
  1. Diameter of part (?)
  2. X-axis location of first hole
  3. Number of holes per row
  4. Distance between holes (in x) in row
  5. Number of equally spaced rows and/or angular distance between rows.
  6. Stagger/shift amount (in x) between alternating rows
  7. Depth of hole
Ideally I would like to make only one lap around the part but, will do 2 laps if I need to in order to accommodate the stagger/shift of the rows.
Hopefully, I can do it using variables and subprograms and the program would be very short. I'm fairly adept at using the subprogram (i.e.; L101) features, however I have never written using variables. If I can do it in Mastercam that’s fine but would like to be able to re-write programs fast, as needed.
Any help is appreciated.
