I'm still experiencing problems with Mach3.
Using the C1 breakout board from CNC4PC.com
+5V is connected to both sides, and the enable pin is hooked up to 5V.
Input side is connected with a male to male parallel cable (not modem or printer cable)
I don't seem to be getting any meaningful output on the pins when I try to jog the system. None of the LED's light up when I jog weight, but the pin2 LED stays on ...
**QUESTION: In Mach 3, under the diagnostics pane, if the system is operating correctly, the squares on the representative pins of the parallel port light up when the system is jogged?? Because on mine, they all remain OFF...
I would be great if anyone could shed some light on this.
Thanks,
Wilson |
