What's the advantage of two motors vs one motor driving a full-width shaft with a pinion gear on each end? (if you're using a rack/ pinion design).
I don't see an advantage but several disadvantages come to mind, potential for missed steps, added expense/ complexity. Unless you simply have to go the two motor route due to design constraints ( clearances etc.). |
