Hope you can help.
Just designing my Drive bearing Block for my Y Axis. The block will be made from 30mm Aluminium and will house a double Angular contact bearing.
To bolt the block to the gantry is it better to use 4-8mm bolts or 2 -12mm bolts. See my attached DXF. The lead screw will be 1600mm thread.
thanks |
