we have that type on one of our 30 x 16.
ours says SMW on the front, it is basically 2 tables you slide in and out of the reciever mounted on the table.
the table size is limited to the door opening, ours is within 1/2 inch of the opening.(loss of actual table size might be 1" per side but actual travel is still intact, did lose about 4-5 inches of z travel with the reciever and table stack up on original table)
we have been using it for over 10 years with few problems, mostly just wear and tear on lines.
works out well for dedicated jobs with several ops (4 ops, 2 on each pallet)
you may want to set up quick change sub plates for your application it didn't sound as dedicated as mine. |
