Thread: OD engraving?
Old 05-11-2008, 12:30 AM
bassn_07 bassn_07 is offline
*Registered User*
bassn_07 is on a distinguished road
Originally Posted by dcoupar View Post
2005's a long time ago, but... to engrave an X at 0 degrees, for example:
Create a chain feature on the ZXY plane at Z0. Use Wrap Contouring to specify the machining parameters.
Hope this helps.
Thanks. That sounds simple enough...I was trying to do it through the engrave feature on the upper tabs. I guess all I need to do is create text in the ZXY plane orientate the way I want it and just use wrap contouring. Thanks again and it helps a ton.
